Hi there !
I’ve experimented that the usb-c wire (cable ?) buyable with fairphone 3 is really résistant. Would you have references for same resistant wires with mini-usb ans micro-usb ?
Thanks a lot !
Hi there !
Thanks a lot !
If you mean the make of the strand, then the keywords “nylon” or “braided” (in your language) in connection with other cables should find you something.
