Hi everyone!
I have two questions:
can i create a folder on my home screen?
i have added a widget on a new panel in the lock-screen, how can i remove it?
Thanks!
Hi everyone!
Thanks!
Hi @Penty,
question 1: Yes, you can. , but let me first answer question 2:
Press your fingertip on the widget until “delete” appears on the top of the screen. Then drag the widget up to the “delete” and drop it there.
Back to question 1 which works quite similar: Press your fingertip on one of your apps you want to have in your folder, drag it over a second app you want to have in your folder. Than drop it and your folder should have been created.
Greetings
Tom
Great!
Thanks so much!
You’re welcome.
Greetings
Tom
