I’d like to replace some sounds with my own, particularly the keyboard typing sound. Where does FP store the keyboard input sound file that I should replace? Thanks.
Cheers
Janne
Cheers
Janne
Hi Janne,
have you searched in the internet how it’s done in Android? I’ve found some forum posts:
http://forums.androidcentral.com/verizon-galaxy-nexus/186933-change-keyboard-click-sound.html
http://androidforums.com/international-gsm-galaxy-nexus-all-things-root/476035-how-change-default-system-sounds.html
Thanks Aexl,
almost works. Unfortunately the phone says “the phone doesn’t support this file type” (or something similar, my phone language is set to Finnish) when trying to play the newly created files, and subsequently there is no sound whatsoever when typing. Beats me why that is - the new files are copies of old system audio files (I’m trying to use a generic system sound as the keyboard input sound).
Cheers
Janne
Have you searched for something like “android change system sound”?
I’ve found this (though it’s old): http://forum.xda-developers.com/showthread.php?t=1125083
