I just got my fp2, and cannot enter data into input fields meant for locations. When i click them, they acknowledge the touch by lighting up, but I never get a cursor or anything.
It seems to work in the Google Maps search field, but not in other apps such as Uber, and a the local public transport app (sthlm traveling) that i have inatalled.
I have just got the phone, and upgraded it to the latest version before testing it, so I cannot say if this changed after the upgrade. I have restarted a number of times and tried with and without location enabled (without should work with some of the apps bit doesn’t). Despite this, the behavour is the same.
Anyone else sharing this problem?
Perhaps it the Privacy Impact
Workaround:
Re-enable Privacy Impact by unticking the option found at:
Settings; Sound & Notifications; Privacy Impact
Ah, I would not have imagined that. It solved the issue for me, many thanks!
