Hopefully this isn’t too complicated but I can’t work out on my new FP2 how to link my voicemail number (443 on giffgaff) so that it is dialled automatically when I pull down and press the new voicemail icon from the notifications bar (which currently says “voicemail number unknown”).
Any help appreciated, thanks!
you can set the number at the settings from the dialer app.
Just open the dialer app an tap on the three dots in the upper right.
Than go to settings -> Call settings -> SUBS Settings -> Voicemail -> Setup
I had no voicemails yet, so i could not test if this solves your problem.
Yes! Tested and it’s done the job. Thanks very much for the help!
