Hey,
I just downloaded the newest version of Lineage OS and i see that i cannot use Orbot on it.When i try to connect it says:
NOTICE: Tried for 120 seconds to get a connection to [scrubbed]:9001 or 443. Giving up.
(waiting for circuit)
Can you make sure it may connect to the outside?
Do you have a firewall active? Check in settings whether it may use network.
Can you resolve the host, e.g in the terminal (just to make sure)
Edit: indeed it doesn’t run for me either… Will look into it this evening, maybe i can see something
I looked around the internet and it seems it is not a FP2 problem but it looks like lineage has some strange configuration for the VPN dialog.Indeed, if i try to bootstap tor it works quite well.The problem is that it can’t connect to the VPN.
