I had this too.
And it appears everytime i reboot or turn on the phone.
Thats my impression too. Especially at the navigation bar.
Does anybody can confirm this? Or is it a individual problem of my setup?
I had this too.
I can confirm this, picture is not in the default directory under DCIM.
Another bug. Some apps did not have network allowance in app settings. After switching network usage on for those it had no effect, only after reboot
My first feeling is the exact opposite. Some actions lag and battery life is not as good as with 8.1
Need to analyse more. My feeling is that the difference could be using Blokada (tracking filter via VPN) uses more battery than AdAway (tracking filter via hosts file). But I wanted to try Blokada because AdAway was the last reason for rooting my phone.
Regarding TWRP-compatible encryption, I just tried the following âŚ
When booting 16.0, I was then surprised when I got asked for a decryption password, when none was set.
For the record:
Other passwords are being declared as âWrong passwordâ, while ânoneâ results in the âDecryption unsuccessfulâ screen.
Does anyone know whether this is a Pie-feature, or the ROMâs: Iâm not sure i can set the notification volume, but i have call volume (whatâs this?) and ring volume. Before, i could set volumes independently
New build uploaded (see 1st post). Fixed: auto-brightness, off-mode charger and notification led settings.
Chris
Thank you Chris! Is there a Github repo, where we can track these latest changes :)?
https://review.lineageos.org/q/project:LineageOS/android_device_fairphone_FP2+branch:lineage-16.0
I think, this is it what you are looking forâŚ
Iâm constantly losing that link ^^⌠thanks!
I noticed something strange with my phone webbrowser: when I start a (big) download, there is a notification from Download manager, but when I switch to another app this notification disappear, and it seems like the download doesnât progress until I switch back to the webbrowser and the Download manager is displayed againâŚ
Is there no way anymore to manually set the accuracy of the location? In Android 8 there was âhighâ, âpower savingâ, âdevice onlyâ.
Didnât see it in Android 9. Just âonâ or âoffâ.
How do I know if GPS is used or not?
Itâs not exactly like Android 8, but in Parameters > Network and Internet > Wi-Fi > parameters of search I found those two options (sorry itâs in French):
Those are now in âSecurity & Location > Location > Extended > Searchâ for me (my UI is in German so those are probably not 100% the English terms).
Seems like there is now way to enable/disable GPS specificallyâŚ
Hi everybody,
I was using the Lineage OS with microg version until now. I formated data to remove encryption, wiped cache and system and then installed the Lineage OS 16.0 with Unified NLP Zip from @Roboe. I managed to install the back up of many apps through Titanium Backup. Some of the apps did not work (for eg: Signal). So i uninstalled the apps which did not work and installed them new without feeding them with data.
So far, everything works. Looks smooth.
I can not confirm Oli.SaxâS problem with the download manager. For me, It works fine.
I will continue to test it the next couple of days and report back here.
Cheers
Re LEDs: one app (wire chat) which had no explicit led setting in the app, now does not use led notification at all. Before, my app specific setting was appliedâŚ
Hi all,
I tried today to copy a file with a file manager from internal storage to the sd card, that is configured as âmobilâ and not âinternalâ.
When selcting the destination folder on sd card, Iâm asked âplease chose first the sd cardâ, and when clicking on âselectâ, a message appears âauthorisation failedâ.
Has someone else faced this, and solved it?
Today my first day with it in real life. I left my flat at 06:15 in the morning. I did everything I usually do with the phone, writing some texts, listening to music, surfing the web, doing calls. So far everything works like it should. Back at home at 20:30, still have 25% battery left. Ok, I donât have so much screen on time, but during work I listened around 5 hours to Spotify.
For me it seems that also the standby time is quite good. So far, I am quite impressed.
Edit: this morning in the train I tested my wireless headphones, they also work.
@Paule What battery % would you have left for a typical day on linage 15? (or which release did you come from?)
Iâm asking because it depends a lot on your overall battery status as well =)
Thanks for the new build!
Adaptive brightness
Off mode charger
Notification LED (but did not have problems before)
Security Patch April 5th
Any guess when this might become official? I am not in a hurry, but feel that it is quite mature already.
Hard to say⌠Letâs say I was just happy that I got home without recharging at workâŚ
I am coming from Lineage 15.
