Saving energy? Are you having problems with your battery? Mine was charged 12 hours ago and is currently at 75%. It is predicted to last for another 31 hours. Am I missing something?
Also, I get the need not to disturb others, however, when you’re saying something might require an immediate response, you’re already taking your phone out and using it, so I guess you’re in a situation where that is okay anyway.
Especially vibration seems neither energy consuming nor disturbing to others, why is it not a good alternative?
I’m still going to stick to sound and vibration off and people having to accept that I am not available to them 24/7. When at home I might switch the sound on when I expect an important call.
the little, but important difference is: the LED light-notification is flashing until you see the notifications. Imagine the same behavior with vibration
I totally understand the need of LED-notifications: while working in loud areas - e.g as a carpenter - or even at home while listening to music: I don’t want to check my FP all the time for new notifications.
Haha I think a problem I might be having is responding to one person’s needs, and then having a reply from someone with other reasons for wanting LED.
So someone said they wanted to know immediately whether they had a message because it would be important to respond immediately, and I was responding to that. That would exclude the option of the phone vibrating for a long time since the person was already primed to receive something and respond immediately.
So summarising my opinion, I would say notifications are quite useful, but I think it’s pushing it to say one couldn’t live without them and there are alternatives, which may have to be different according to your personal needs.
Now, feel free to carry on bewailing the absence of the LED notifications, I’ll leave you to it as this is quite clearly not my support group
I lived the major part of my life without a mobile phone. Even more without a smartphone. And even more than that without a LED notification. I could still live with a mobile phone, without “smart”, without a notification LED. The point is that I don’t want to. I’ve become used to that state of the art.
If i understood correctly:
a) the FP3 hat only a LED “notification” just to inform about the charging state of the battery:
red color low 0-x% charge and before y% will be reached and
green one y-100% is reached
No LED light or no color the battery charge is normal.
Right?
b) It could be good to have another type of LED “notifications”, right?
c) Is there a place where the “suggested or requested” features can be registered
and follow up?
Why do you assume I want to react immediately? I just want to know if something is there without having to turn on the display. Nice that your battery lasts so long, with the small LED it would last even longer.
I did not assume that at all. Like I said, the confusion arises when I respond to someone, in this case HaukeFP3, taking his situation into account, and then get told what a bad idea it is because someone else’s situation is different. I already explained this in my previous post.
This would perhaps be convenient, but it would not be relevant in any way other than demonstrating your support for it to this forum, which is a community of mainly users, not the company.
If you really, meaningfully want to express your wish to Fairphone to get this feature, then currently there’s no way around telling Fairphone directly …
Thanks, AnotherElk! I can’t believe they didn’t make a feature/bug out of this one yet (that I have been able to find at least). I contacted the helpdesk to ask about getting this working. Let’s hope it’ll be implemented soonish!
y is 89 or 90 from what I’ve seen btw. Also it seems to me that that LED emits yellow light below y%. Maybe it’s really red if the battery is very low, but IIRC my battery has never dropped below 35% so far so I can’t really say anything about that.
__
Generally speaking I don’t care too much about the notification LED–FM radio for instance would be much more important to me–it would be nice to have however. So let’s hope for the best.
There is another alternative: use a smartwatch, set up which notifications get forwarded, and then put vibration on during on hours.
I have my smartphone almost always on DND, and I still hear calls from the vibration motor alone. If I was deaf, I’d probably use the vibration motor more, or the above mentioned smartwatch solution. Remember, there’s more ways to vibrations. I came across one innovation where the vibration motor was on the arm, and different parts meant different things.
If the notification LED is incredibly important to you and you are willing to tinker around: it works for me on ArrowOS GSI. Telegram makes it blink blue.
This also indicates that everything is right with the drivers and the kernel, fairphone only has to fix their android.
