I am trying to change the language but the phone shows no reaction.
While trying I believe I got a short notice saying that this required root access, which seems strange. Also, I can’t seem to reproduce this message.
Thanks for your ideas!
Are you in the right settings option?
Do you mean you can’t reproduce the problem?
The FP is currently in French, so I go
Paramètres -> Langues et saisie -> Langues
Then I click on one of the choices there, and nothing happens.
You click? Normally you have to drag them to order them in a list as first, second, etc.
Example:
Ha! That was it. I feel really silly
Thanks!!
