Key combination for turning off vibration
Hello
The vibration can be activated by pressing the “On/Off” and “Volume Up” buttons simultaneously. I often find that I accidentally activate the vibration function. How can I deactivate this combination?
If I understand it correctly, you need to deactivate
Settings > Sound and vibration > Shortcut to prevent ringing > Use prevent ringing
(or one step before: Settings > Sound and vibration > Shortcut to prevent ringing)
Perfect! Thank you for your prompt reply. I hadn’t found that switch.
