Kernel hackers: upstream kernel for FP2 OpenOS?
It’s upstream :tada:
But isn’t this the device tree only? An upstream kernel alone still couldn’t address all of the Fairphone’s hardware as it still contains parts which work with closed source/out-of-tree drivers only, am I right?
And I’ve put build instructions on a repo on GitHub linked in the top post. Also if anyone could update that post (eg section “challenges left include” as it’s outdated a bit. Maybe also mention that some stuff is in torvalds’ repo already :slight_smile: ).
This is super cool!
Chris
What are the advantages of having this upstream apart from the obvious one that no longer the FP2 specific code has to be backported? Did I understand correct that this means Oreo may officially run on the FP2?
Probably not. I alone will probably never get all hardware components of the FP2 working nicely and even if, getting Android to (smoothly) run on it is another challenge afaik.
Not related to oreo. Oreo can be done with older kernels. I have not started oreo work as N is still not working properly and no other lineage device anyway has oreo nightly builds.
This is nevertheless super cool.
Chris
Google “requires” a 3.18 or 4.4+ kernel for Oreo depending on the device for Google Certification so that’s what I guess is meant with “officially”.
But yes, technically Oreo doesn’t need a new kernel version (except a buttload of backports)
No need to hurry :slight_smile: i think we’re perfectly fine with Nougat for some time, which is working great, btw. Switching to a more or less alpha oreo is premature, imho
But still, a more modern kernel will always be welcome…
Will this benefit with Project Treble in the FP3? I mean, will make easier things like upstream the kernel or use freedreno?
Short answer: No.
That’s what I am basically doing for the Fairphone 2.
Nice to know, it sound very promising :smiley:
