Is the Fairphone 5 Hi-Res audio compatible?
I have been using a Samsung S10e for years and I am considering buying a Fairphone 5, considering my Samsung is dying.
What looks great with the Fairphone 5 is that it has an SD card slot, which I need.
But I don’t find any information regarding the audio capability of the phone: is it able to read and send Hi-Res audio music (using Foobar, for instance) to an audio device? (preferably a wired headset).
Many thanks for your help!
Hello, here is the audio specs from the website:
The supported formats include: SBC, AAC, aptX, aptX HD, LDAC.
just a quick note, the FP5 does not have the audio-jack, in order to use the wired set, you need the adapter, like the one offered in the webshop
I do not know where you are based but perhaps it could be possible to test the quality of the sound in a local shop or ask the local Fairphone Angel for help?
