I have a FairPhone 1 and I’d like it to have Bluetooth 4 support. Is it possible to connect as a second Bluetooth adapter through the USB port? I’m thinking in something like the one in the attached photo. Is there a way I can configure Android to use it instead of (or even better, in parallel with) the internal one?
Looks and sounds highly unlikely to me (I doubt the FP1 can handle this adapter).
I think it would be easier for you, if you installed Android #kitkat !
