Hey guys, I have been using a FP6 for a bit over 6 months and once I got it, I flashed to e/os. It has worked great and I got really used to it with some hiccups here and there.
But recently I went out of the country and roaming worked for a bit and then stopped completely. I had roaming available in my carrier, checked that the sim worked in other phones and that other sims worked in my phone. Now back at home, old sim does not work and had to get a new one. And new sim is still struggling with reception which it never did.
Wifi is also an issue, like some, my wifi is choppy and has been disconnecting with no reason which then I need to restart and fixes whatever issue there was.
anyone has a solution for these? Its getting to a point where I am considering jump back on Android
