Installed Klarna App on FP6 does not work?
Hi, I have installed the Klarna App on my Fairphone 6.
When I try to run it I can log in (codes via email and mobile) but it won’t go beyond the next screen where you can select Continue in the App or Continue on Web.
Continue in the App does nothing (no action).
Continue on the Web does work (after re-entering the login stuff).
Has anyone successfully installed the Klarna App and got it working fully?
Thanks
James
I am using the app and haven’t had any problems (Version 26.19.213 com.myklarnamobile).
I just cleared the app data and did the setup again and there is no such “continue” screen/option, after entering the code from the email it goes straight into the app and everything works.
What ROM do you use?
Klarna works flawlessly on my FP 6 with e/OS 3.7.3.
