KAI
October 23, 2014, 9:07am
1
Hey there,
I managed to set different ringtones for my special contacts.
And now it works “too good”. I mean the individual ringtone is played not only for calls but for messaged aswell.
This is a bit confusing and sometimes enerving when a lot of messages arrive and the long ringtone is played.
So, is there a way to fix it?
best wishes
Kai
Continuing the discussion from Different ringtone for every contact :
@Matthias
First of all yes, as you imagined, only contacts that are saved on the phone can have a personal ringtone.
If your contact is on the sim card, then there won’t be any option to set the ringtone.
Second, you need to make sure that the desired ringtone is indeed in the Ringtone directory.
Now the procedure:
Launch the “People” application
Select the contact (a new page/view will open)
Tap on the “Settings” button (the one on the lower left, next to the home button) and a dialog will open
Tap on “Set ringtone” as shown in the attached image
<img src=“/uploads/default/479/ac4da5ddf23d3f25.png” width=“281” height=“500”>
(edit, by Herve5)
I am quite ashamed to edit a post not mine (I don’t even understand why this is possible -maybe because the discussion is closed); this is to say, the procedure to move a contact from the SIMcard to the phone memory is not obvious, while most certainly the situation where all contacts are in the SIM will happen to most newcomers.
The only way I found is asking to ‘associate’ said contact with a given Sim (out of the two), which triggers the duplication of the contact into the phone memory. Then by editing that second contact one indeed has access to dedicated ringtones, contact avatar etc.
Sorry again for this shameless edit…
H.
Hi everybody,
I searched here and in different forums but found nothing helpfull. Mostly there was written: “go to the specific contact –> than push the menu button –> an go for setting ringtone”. I can´t find anything like this on the FP. Also I tried it thrue the audioplayer, selecting a song and looking for some settings, but the only thing I can do is setting this song as general ringtone.
The songs I want to use are stored in my SD-Card in the specific folder structure so I could choose them as general ringtone.
So the questions is how can I set individual ringtones for every contact ???
Does it deal with the storage locations of my contacts (in my case it´s the SIM)???
Sincerely
Matthias
Depending on what Kind of Messages you are talking about, the solution might be found right here:
Hello everybody!
I’ve got the following problem:
I have chosen a special ringtone for the members of my family. When I receive a WhatsApp message from one of them the ringtone is the same as the one for an incoming phone call. However, it should be otherwise, as I appointed another sound for an incoming message. It seems as if the settings concerning the ringtones would override the settings for the message tones.
Does anybody know how to solve this? I would like to have different sounds for …
Herve5
October 23, 2014, 2:47pm
3
Kai,
I don’t know what exactly happens in your settings, but in my case I have a specific ringtone for my S. O. and I can tell that anyhow the beep when she just sends me an SMS is still the standard one…
