Idle battery drain
Hello, my Fairphone is on version FP6.QREL.16.82.0 and in this update I’m experiencing constant battery drain, even when I’m not using it. This week, I could’ve overslept twice (if it wasn’t for my home automation) due to the phone being completely drained from 60+% before I went to sleep.
The biggest culprit I’ve found is that my screen seems to be always active (almost every “bar” shows me screen battery usage and activity of over 70%)
I never have “Always On Display” active.
Anyone else experiencing this problem?
I currently have issues with over night drain in airplane mode showing CPU as culprit…
Did you try to reboot the phone?
I experience this every now and then. AccuBattery seems to indicate that the phone fails to go into deep sleep sometimes, when inactive. A reboot usually resolves the issue.
