hi i can not remember the symbol code to unlock my phone how can I reset it ?
You can do a factory reset as described here: https://support.fairphone.com/hc/en-us/articles/115001610926
As you do not have the unlock code, you should use the procedure under the heading âFairphone 2 doesnât start anymoreâ.
Do not forget to check the section âGoogle Security Featureâ. You may need to log in with the Google account linked to the phone after the first reset. After youâve done this, Iâd suggest performing the procedure listed under âfairphone 2 starts normallyâ, as this second reset will also remove the Google account. The reset via recovery will not do this, it has to be done via the settings menu in Android.
