Today I wanted to switch to OpenOS since I don’t want Google Spyware on my phone (I only need the Play Store). But then I discovered that is impossible to run the Play Store on OpenOS even if you download the apk directly from the intenet, so I used Updater to switch back to ClosedOS (?). But now my phone is black and I am not able to turn it on anymore.
I only used original software from code.fairphone.com.
Don’t do any important changes to your phone, if you have no clue about that all! Read first, then read more, then think about that all, then read even more.
1.) Google-play-store needs Google-services-framework, so installing play-store does nothing.
2.) If you don’t want Google-apps on your phone, start with disabling those apps on your phone. Disabled apps do nothing! And: you can go back very easy …
3.) You can control your phone better by getting root-rights, but for that you have to read, what written here about root.
4.) Your phone knows 3 ways to operate:
a) you press power until it vibrate and the phone works normal
b) you press and hold volume-down and press power. The phone shows the droid and if you connect your phone to a PC you can do several “things” via dos-mode to your phone. Needs many knowledge …
c) you press and hold volume-up and power. The phone shows a kind of terminal with a menu. You can step through the menu-items with volume up and down, chose an item with power. Try “reset to factory” …
Spielmops
PS: Windows can not read the storage on your phone in a normal way until the phone operates normal.
