I rebooted my phone now it says android.process. stopped
I just got my new FP. at first I updated to the stock android.
Here I could not instal google play.
So i rebooted to the fairphone OS I found in the support section.
Now my phone says: android.process.media stopped. And I can’t do anything!
any ideas?
This should help you. :slight_smile:
Thanks,
my keyboard also keeps on failing. I’ll just install another one :smile:
The keyboard problem should be resolved after the installation of Google Apps.
