I didn’t see where you mentioned it before (this forum layout is confusing
Sometimes there’s issues with copy/pasting adding weird line breaks, depending on where you copy/paste from so I thought I’d mention that too. (I’ve had that issue before when adding keys to my authorized_keys file.)
I just have deleted my whole branch yesterday and now i need a halfway latest FFOS Image which is working. Can someone please send me a build from the last week? Downloadspeed 200kps sucks for another buildingstart. Would be great! jom
Obviously a new version of FPOS has been released today. Would you guys know if the sources are updated as well, i.e. would it make sense to download and compile again?
And would I still need to apply the Unified NLP patches to have network-based location on a Google-free FPOSOS?
I have to admit that I didn’t check myself, but I would assume that you can answer your questions by looking at their gerrit… Afaik some pull requests have still been open.
I tried cloning the fairphone osos repos as described in the build instructions, but the given http-address 404s and the ssh-address gives “Permission denied” although i did add my key in gerrit. Does anyone know where else i can get the sources?
If you are running Ubuntu 16.04 which uses OpenSSH 7 then you will need to add a .ssh/config file with the gerrit host to allow the right cypher: http://www.openssh.com/legacy.html
For Example:
user@skylake:~/fairphone_os$ repo init -u ssh://code.fairphone.com:29418/fp2-dev/manifest -b fp2-sibon Unable to negotiate with 37.187.31.110 port 29418: no matching key exchange method found. Their offer: diffie-hellman-group1-sha1
Here is a log: http://termbin.com/5xdj
It basically just rejects my key, but i did add the key to gerrit, so i suspect that the repo is gone/changed location (especially in conjunction with the http-access 404ing). Can you please test whether the repo init -u ssh://code.fairphone.com:29418/fp2-dev/manifest -b fp2-sibon command currently works, to exclude that possibility.
Thanks for your testing.
Replacing the line in the known_hosts-file had no effect (eyeballing, the old line had the same fingerprint). I can confirm that i did a ssh-add and ssh-add -l shows that the key is indeed added
I moved my ~/.ssh directory, generated a new key, added it to gerrit and modified ~/.ssh/config and ~/.ssh/known_hosts as necessary. repo sync fails, saying that it requires repo init first. The googlesource.com connections are missing if i do not delete the .repo directory, so you probably had that still lying around (Did you try in a completely fresh directory?). repo init -u ssh://code.fairphone.com:29418/fp2-dev/manifest -b fp2-sibon still fails with “Permission denied”.
I played around with repo today and changed my manifest to: default remote="origin" revision="fp2-sibon-2.0.2" Will I get more recent code with this branch?
Update: I do not understand how the manifest works. Can someone explain me how to switch to the latest “meta” branch/revision that matches the code from the latest update (1.2.8)?
Yes, I did. As said, the http-repo-url seems to work despite the 404, so I don’t care about the broken ssh-auth anymore (I just need the repo to build a google-free image, would be much easier if fairphone offered a prebuilt image …).
Unfortunately, the build fails with some obscure linker error (log: http://termbin.com/545w).
