As said before, I get errors when adding cp -R recovery/root/sbin $(TARGET_RECOVERY_ROOT_OUT) into build/core/Makefile. But I do see the files there in /out.
I did add that line to init.rc.
Meanwhile I managed to almost-root it through adb - SuperUser is automatically rejecting all root requests though. One of the steps I had to take was to disable SELinux, but it only lasts until I reboot the phone, couldn’t figure out how to make it permanent.
I realized that the system/xbin/su file showed as empty from Amaze. I noticed that this is because of SELinux. Seems that it restricts access for nearly everything, except ADB shell. ADB doesn’t work for me, don’t know why. Works without problems with my FP1.
Anyway I found a hint here Disabling SELinux in Android 5.0.1 - Stack Overflow
So I added
to device/fairphone_devices/FP2/BoardConfig.mk. This requires to flash boot.img as the kernel cmdline changed.
With that change Amaze can see correct details of xbin/su. SuperSU tries to copy new su at least, unfortunately without success.
OpenGApps can be integrated quiet easily using this: https://github.com/opengapps/aosp_build
Only some lib files need to be moved or alternatively make files modified.
I tried with nano variant:
I also tried koush’s Superuser today (https://github.com/koush/Superuser). Integration was no problem, but didn’t work either. It looks like that SELinux stuff makes it complicated. There is a fork of that abandoned project: https://github.com/phhusson/Superuser
It states that it has most of SuperSU’s functionality. And its open source. That is what we want, right?
I’ve fooled a bit with Superuser a week ago, but SELinux prevented me from making it work (or at least I think so). I’ve tried installing their su binary by hand but it’s inaccessible from apps (trying to access it with a terminal emulator returned an error saying something like this : "access forbidden for pid ").
Sorry for the spam but I think this deserves a separate post. Has anyone else had huge battery drains during sleep mode because of the AOSM “mail” app ? I went from 80% to 46% battery overnight because of it.
Using K-9 only brought me from 98% to 96% overnight…
EDIT: @Arvil I was seeing K-9 Mail use around 33% of my CPU in the stats. Then I was looking for something else and enabled “Background Sync” in Settings -> Accounts -> three dots. K-9 Mail disappeared from the statistics. Of course I have set it to poll every 30 minutes and use push normally, but it might give you a clue.
I just removed the “untested” warning. I tested it myself on two devices (both with unofficial images) and it worked, and @lklaus tested it on a device with the official image.
Ideally I’d like to create an already rooted image, but I can’t figure out how on earth to do it
I just had an idea, there should be no blobs involved in the recovery image, right? So in theory we could make a blob-free recovery.img and distribute it?
Good question/idea. I’m not an expert. If a clean build without the blobs is successful? I think so
The recovery is Android Open Source Project/Apache 2. I’m sure there are nicer recoveries out there, but this one is as good as any to start with. A few checksums here (if a build without blobs is successful) will help as well.
I don’t think checksums are usable, the build contains information about your username, computer name, date/time, kernel on your computer etc. But I might try a clean build without blobs just for the sake of it. It’s just a hassle to have one more directory of a clean repo sync
Docker might help while experimenting? (make clean and clean out /vendor/qcom/proprietary) fp2-sibon-2.0.0-blobs.sh is just a zipped tar file cp’ing stuff to ./vendor/qcom/proprietary/. The rest of the magic (that should not be used) is in ./vendor/qcom/proprietary/vendorsetup.sh
(Update, my time to look into this is up, but I’m sure most of it can be found in build/core/Makefile)
What’s the problem with that? Isn’t everything in the repo supposed to be in git repositories? It should be fairly easy to store your changes (in a different branch or you can git stash your changes). Or you checkout to a different working directory which uses almost no additional disk space because everything is stored in git anyway and only hard-links are checked out.
A build without the blobs probably won’t work (because compilation will fail on one or several make targets). It’s also unlikely the recovery system will be free from licensed stuff since there are several sh files with “qcom” in them in the recovery “root” dir.
I did a quick “make -j8” here, looked okay, just a few standard unix tools getting complied. But maybe I’m missing a lot here, it was just a small random test without really looking into it.
Recovery image (in build/core/Makefile, search for # Recovery imag) and (bootable/recovery/Android.mk) or is there more? But @lklaus is our recovery expert, so I just wait for his answer.
I’ve same problems compiling the source.
I’m using Debian Jessie (8.2). I installed gcc-4.8 and tried to use update-alternatives. But I get this error: “update-alternatives: Fehler: keine Alternativen für gcc”.
I don’t konw wether this is a problem or not.
Why I’m writing is, that make ends very soon with the following error:
> Export includes file: external/openssl/Android.mk – out/host/linux-x86/obj32/STATIC_LIBRARIES/libcrypto_static_intermediates/export_includes
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/RecognitionException.java:30: error: package org.antlr.runtime.tree does not exist
> import org.antlr.runtime.tree.*;
> Export includes file: external/zlib/Android.mk – out/host/linux-x86/obj32/STATIC_LIBRARIES/libunz_intermediates/export_includes
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/MismatchedTreeNodeException.java:30: error: package org.antlr.runtime.tree does not exist
> import org.antlr.runtime.tree.TreeNodeStream;
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/MismatchedTreeNodeException.java:31: error: package org.antlr.runtime.tree does not exist
> import org.antlr.runtime.tree.Tree;
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/MismatchedTreeNodeException.java:41: error: cannot find symbol
> public MismatchedTreeNodeException(int expecting, TreeNodeStream input) {
> symbol: class TreeNodeStream
> location: class MismatchedTreeNodeException
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/Parser.java:30: error: package org.antlr.runtime.debug does not exist
> import org.antlr.runtime.debug.DebugTokenStream;
> Import includes file: out/host/linux-x86/obj32/STATIC_LIBRARIES/libunz_intermediates/import_includes
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/ParserRuleReturnScope.java:30: error: package org.antlr.runtime.tree does not exist
> import org.antlr.runtime.tree.CommonTree;
> Import includes file: out/host/linux-x86/obj32/STATIC_LIBRARIES/libcrypto_static_intermediates/import_includes
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/UnbufferedTokenStream.java:30: error: package org.antlr.runtime.misc does not exist
> import org.antlr.runtime.misc.LookaheadStream;
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/UnbufferedTokenStream.java:50: error: cannot find symbol
> public class UnbufferedTokenStream extends LookaheadStream implements TokenStream {
> symbol: class LookaheadStream
> Export includes file: system/core/adb/Android.mk – out/host/linux-x86/obj32/EXECUTABLES/adb_intermediates/export_includes
> Notice file: system/core/adb/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//bin/adb.txt
> Notice file: system/core/libzipfile/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//lib64/libzipfile.a.txt
> Notice file: system/core/libzipfile/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//lib/libzipfile.a.txt
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/RecognitionException.java:110: error: cannot find symbol
> if ( input instanceof TreeNodeStream ) {
> location: class RecognitionException
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/RecognitionException.java:124: error: cannot find symbol
> TreeNodeStream nodes = (TreeNodeStream)input;
> Notice file: external/zlib/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//lib64/libunz.a.txt
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/RecognitionException.java:126: error: cannot find symbol
> TreeAdaptor adaptor = nodes.getTreeAdaptor();
> symbol: class TreeAdaptor
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/RecognitionException.java:152: error: cannot find symbol
> else if ( this.node instanceof Tree) {
> symbol: class Tree
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/RecognitionException.java:153: error: cannot find symbol
> this.line = ((Tree)this.node).getLine();
> symbol: class Tree
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/RecognitionException.java:154: error: cannot find symbol
> this.charPositionInLine = ((Tree)this.node).getCharPositionInLine();
> symbol: class Tree
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/RecognitionException.java:155: error: cannot find symbol
> if ( this.node instanceof CommonTree) {
> symbol: class CommonTree
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/RecognitionException.java:156: error: cannot find symbol
> this.token = ((CommonTree)this.node).token;
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/RecognitionException.java:171: error: cannot find symbol
> else if ( input instanceof TreeNodeStream ) {
> Notice file: external/zlib/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//lib/libunz.a.txt
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/RecognitionException.java:172: error: cannot find symbol
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/RecognitionException.java:173: error: cannot find symbol
> Notice file: external/openssl/NOTICE – out/host/linux-x86/obj/NOTICE_FILES/src//lib/libcrypto_static.a.txt
> Export includes file: system/core/libbacktrace/Android.mk – out/host/linux-x86/obj32/SHARED_LIBRARIES/libbacktrace_intermediates/export_includes
> Export includes file: system/core/libbacktrace/Android.mk – out/host/linux-x86/obj32/SHARED_LIBRARIES/libbacktrace_test_intermediates/export_includes
> Export includes file: external/gtest/src/Android.mk – out/host/linux-x86/obj32/STATIC_LIBRARIES/libgtest_host_intermediates/export_includes
> Export includes file: external/gtest/src/Android.mk – out/host/linux-x86/obj32/STATIC_LIBRARIES/libgtest_main_host_intermediates/export_includes
> Export includes file: external/libunwind/Android.mk – out/host/linux-x86/obj32/SHARED_LIBRARIES/libunwind_intermediates/export_includes
> Export includes file: system/core/liblog/Android.mk – out/host/linux-x86/obj32/SHARED_LIBRARIES/liblog_intermediates/export_includes
> Export includes file: external/libunwind/Android.mk – out/host/linux-x86/obj32/SHARED_LIBRARIES/libunwind-ptrace_intermediates/export_includes
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/UnbufferedTokenStream.java:50: error: UnbufferedTokenStream is not abstract and does not override abstract method range() in TokenStream
> Import includes file: out/host/linux-x86/obj32/SHARED_LIBRARIES/libunwind_intermediates/import_includes
> external/antlr/antlr-3.4/runtime/Java/src/main/java/org/antlr/runtime/UnbufferedTokenStream.java:75: error: cannot find symbol
> public int LA(int i) { return LT(i).getType(); }
> symbol: method LT(int)
> location: class UnbufferedTokenStream
> Note: Some input files use unchecked or unsafe operations.
> Note: Recompile with -Xlint:unchecked for details.
> 23 errors
> build/core/host_java_library.mk:84: recipe for target ‘out/host/common/obj/JAVA_LIBRARIES/antlr-runtime_intermediates/javalib.jar’ failed
> make: *** [out/host/common/obj/JAVA_LIBRARIES/antlr-runtime_intermediates/javalib.jar] Error 41
> make: *** Warte auf noch nicht beendete Prozesse…
> Note: Some input files use or override a deprecated API.
> Note: Recompile with -Xlint:deprecation for details.
> #### make failed to build some targets (01:45 (mm:ss)) ####
