I can’t suppress it, only modify it, and it disturbs me a lot all the time
Thanks in advance for your help
If you are talking about a screen lock PIN, you can change the screen lock settings at
Settings > Security > Screen lock.
You might also opt for a fingerprint scan, which leaves the phone still somewhat protected
You can also use Smart Unlock. This allows to unlock your phone based on your location, connected devices or face detection.
