I want to set the camera software so that pictures are written on the SD Card, instead of in the internal storage ?
How can I do that ?
Thanks
How can I do that ?
Thanks
You can choose where to stock an app.Go to 'System settings’Under the sub ‘DEVICE’ tap on "Storage"Under the sub ‘DEFAULT WRITE DISK’ you can choose either the Internal Storage of your SD card.
Thank you Lidwen. it works.
However I would have expected more control and be able to choose each application where to store data.
I think it depends on the app you are using. Some let you choose the default write disk in their own settings. The stock camera is not one of them unfortunately.
OpenCamera, for instance, offers that option.
