Mimsy
#1
Hello all!
I have a problem that my FP2 loudly vibrates even when the ring volume is turned right down and the ‘also vibrate for calls’ has been switched off.
Does anyone have the same problem? I’m starting to upset people in the library!!
Thanks!
X
Friek
#2
The silent mode is the vibrate mode. If you want it completely silent, you need to choose the mode “Do not disturb” (circle)
Mimsy
#3
Ah ha! Thanks! Let me give this a go - library readers will be pleased!
Thanks!
system
closed
#4
