But sometimes you have to go with the circumstances, insisting that it has to be different doesn’t help. And if there is an absolute equivalent alternative, I can’t see why there has to be a change.
BTW Android 12 will look different again .
i went back to stock android 12 on my pixel 5…horrible
thank goodnes it’s only for testing
the design speech of android 12 is like barbie and ken for 10 years old girls…
The times they are changing…
hahaha…loks like windows vista but only flat…
I use nova launcer for years. It works great and is higly adjustable.
You used to be able to land icons on top of each other to make a group? I used this to put all the Goo apps in one icon, labelled how you like, and maintenance and utilities in other single icon / folders. I haven’t tried it recently as I use different screen pages instead.
I think it will be the best compromise thank you
Does anyone know how to change fast camera launch from double press on power button to volume button ?
Thank you again
As far as I know, it’s not possible to change the shortcut.
ok thank you for your answer
Did you manage to remove the searchbar with this app? So far I’ve been struggeling to find a FFOS Launcher for FP4 which allows me to remove the search bar. Or maybe I’m just blind.
@Pons
include the izzy on droid repo to f-droid and you will find an actuall lawnchair launcher
reborn…
@Pons I would recommend Lawnchair too, it’s both the most intuitive and customizable launcher I’ve come across over the years. The older version from the Play Store works without a hitch for me as well.
I removed it with Nova Launcher
