How to get contact numbers from sim-card to phone?
Question from Stefan:
I couldn’t find the option which enables me to transfer the contact numbers which are saved on my sim-card to the phone. Can anyone help me out here???
Answer from @Lidwien:
For copying contacts you don’t use the app ‘telephone’.
  • You must use the app ‘People’
  • Open the app, then tap the button far left down on your phone.
  • Now you get the options.
  • The third option is import/export. This is the option you need.
  • Just tap on it and then it asks from with card you want to copy, next choice is copy to where.
  • Now you have to option to copy just a few contacts by marking them or if you want to copy them all just tap on “0 select” right on top of the list and you get to option to copy them all.
This question is originally posted on the old forum.
