How to downgrade eOS?
The new version is buggy. I want to downgrade to the old version but I can’t find where to download it. The ecloud.global build site only has the latest build.
If your bootloader is locked, it’s not possible without bricking your phone, because the anti rollback protection will be triggered.
If you are using a FP4 a release 4.3.1 is available.
It is possible without bricking, however the bootloader cant be relocked.
In this case all data will be lost. Locking and unlocking will trigger a factory reset.
