Can anybody tell me how I can delete a contact?
Answer from Sylvia:
- Go to the ‘People’ App
- Tap the Settings button on the phone
- Select ‘Delete a contact’
Addition from @Lidwien:
For deleting a contact you don’t use the app ‘telephone’. You must use the app ‘People’.
Open the app, then tap the button far left down on your phone.
Now you get the options, the first option is ‘delete a contact’. Tap on 'delete …'
Mark the contacts you want to delete. Finally tap on the ‘ok’ in the right upper corner.
If you want ALL the contacts to delete, then don’t mark contacts, but tap on “0 select” now you get the option to delete all contacts. Tap on this option and then “ok”.
This question was originally placed on the old forum delete a contact.
