I can not flash Magisk with the standard Recovery. CWM or TWRP (which are not ported yet) are required.
Why can’t I flash and start Magisk with adb?
TWRP is not ported yet. It needs Kernel and driver parts of the published sources to be complete and correct. Thus, before someone is able to build FP3 SW from sources and proof it working (flash with adb) it does not make sense to start porting TWRP.
Magisk does not need to be ported. I understood that its quite device agnostic
Magisk only works on TWRP according to their website. The stock recovery checks signatures and / or doesn’t have the required functionality implemented I’m guessing.
adb is usually used for getting a shell and pushing/pulling files to/from the device, for debugging. You can also use adb (adb sideload) to push installation zips to the device and they will be installed but that only works in the recovery (see answer above). On the running Android system you don’t have any special permissions and can’t modify boot or system partitions - that’s only possible through a different system that basically doesn’t use the permission handling of Android
You need either the kernel extracted from a stock boot.img or a self-compiled kernel from the Fairphone-released kernel source code in order to get a custom system like TWRP working. Unfortunately I haven’t gotten the compiled kernel booting yet - and Fairphone doesn’t provide factory images yet to extract the kernel from.
downloading the sources took ages over a 100 MBit/s connection
forgot to check my clock, so I don’t know the real duration, but 2+ hours would be a good guess
could that be sped up by tweaking repo sync? I could imagine it downloads more than necessary if one just wants to build one version for one device
before starting the actual build the folder had ~70GB
the initial build took 04:53:51
real 294m7.497s
user 859m27.531s
sys 512m39.719s
after the build, ~133 GB space was used (using a CCACHE setting of 50 GB)
That’s on a Windows 10 version 19.09 laptop with i7-6700HQ @ 2.60GHz (4 physical/8 logical cores), 16 GB of RAM and a 1TB WD10SPCX-24HWST1 5400rpm magnetic disc (the laptop has a 128 GB SSD but that’s already used for everything else).
Build environment is Ubuntu 18.04 Core running under the Windows Subsystem for Linux.
[Update]: initial build time, final disk usage and computer specs
