How many esims Fairphone 4
Can you then switch back? I have never used Airalo
It worked very well in Panama and Costa Rica.
Switching back and forth is no problem at all.
in the screenshot you see them at the moment deactivated. To activate just click on them. Piece of cake! Just the installation with Airalo might be a bit cumbersome if you don’t have wifi.
Thanks!
I think this might just be what i need.
And how is Airalo working? Can you do with only that or do you also use a local sim?
Just Airalo in my case.
Mind you Airalo is only for data. (Expensive) calls are with your original provider.
