When I asked if anyone knew if Calyx were likely to extend support to 2028 in the Calyx OS matrix chat, the response was that:
“The problem is FP4 being on an older Android version. It will depend on if they update it or not.”
I believe it’s Android 14 being referenced as this issue but I think e/os is now on Android 16.
Would anyone know if further updates will continue to 2028, as I’d love to go back to Calyx but I don’t think it’s quite worth changing the ROM if I have to change OS again in December.
As usual the best guess is to look at what happened in the past.
So far Fairphone has supported OS updates for their devices as long as Google supported the major Android version.
So far Google supported a major Android version for about 3.5 years (see Android OS | endoflife.date)
Which means: the FP4 is currently on Android 15. Given that A13 support ended March 2026 and the “support timer” of A15 started 2 years after A13, I personally expect the FP4 to be supported until early 2028. And in case Fairphone manages to upgrade the FP4 to A16, we’re likely to get another year of software support, i.e. early 2029.
Edit: if I were to guess why the CalyxOS page only says “December 2026”, I’d say that entry was written when the FP4 was still at A13 (A14 was skipped), i.e. that was their assumed EOL for A13. Though I don’t understand why they went for December instead of March the next year.
Which leads me to the advice of contacting the Calyx people to update their page or ask them why they stick to December 2026. I may have overlooked something they know.
Update: After going back to the Calyx matrix chat room the following update was provided:
"We’ve managed to get FP4 on A17 so it should be supported for longer, as long as A17 is supported in this case.
It’s still a challenging device to support because of both the kernel versions and original manufacturer version, so we can’t be sure what the situation will be with the next Android release, even QPR2 could change that."
Fingers crossed the support continues and a massive thank you to the team!!
