The MTV rhapsody music App stores as default files in internal memory, mounted under /storage/emulated/0. I like to change that so that music will be stored under sd-card. What is the mount pount to select sd-card.? I tried all imaginal settings.
i believe the path to the sd card is: /storage/sdcard1
Yes I can confirm that this path to the SD-card is correct.
