How do I select a ringtone for a specific notification (texts)?
Hi. I would like to hear a specific ringtone when I receive a text. How do I do that? And how do I select specific ringtones for specific notifications?
Tap on the ‘settingsbutton’ far left below on your phone.
Choose’System settings’
Choose ‘Audio profiles’ in the second block called Device
On the right of the General profiles you see an icon.
Tap on that icon.
look under NOTIFICATIONS
Tap on Default notification sound and then you get the option to pick another ringtone.
As far as I know it’s not possible to choose a specific ringtone just for receiving sms.
Actually I think I found it : I can set a ringtone for default notifications in settings > audio profiles > general settings > notifications. Then I can go in the text messages app, open the settings panel and change the ringtone for the text messages only.
I’ll see how that works.
As the correct answer has been provided, this topic is now closed and new replies are no longer allowed.
