I have a FP2, build 18.09.2, android 7.1.2.
How do I change the system font? I don’t see an option for it under settings / display: I can change the font size but not install a new font or select another one.
Thanks for any help!
According to this, “stock Android lacks the ability to customize your system font”.
Fairphone OS is almost stock Android.
So, you might look into installing #launchers which might offer changing the font, or you could have a look into Apps like FontFix, but changing the system font probably will require you to #root the phone.
