I can’t find “USB internet” on my fairphone2. how is it translated to german? or does it only exist on fairhpone1?
thanks in advance
thanks in advance
I guess you are searching for this
Einstellungen > Mehr > Tethering & mobiler Hotspot > USB-Tethering
No, I think he/she is looking for the option to use the PC’s internet connection with the FP2. It’s called “reverse tethering”.
With a quick web search I found out, that this Android function was removed with KitKat.
But there seem to be other software solutions for rooted phones running later OS versions, like for example the ones suggested here.
