My phone rebooted and the homepage has changed: no recently-used apps, just two pages of apps with no Settings icon. What do I do?
I guess you accidentally deleted your “My Apps” widget. To get it back, long press on an empty sport on one of your homescreens. Then tap on widgets, look for the “My Apps” widget, press it, hold it, drag it to the right and drop it as soon as a new homescreen appears.
Thanks, Irina. That problem solved!
