I recently got a Fairphone 6+ and was hoping to install /e/OS, but I’ve run into an issue with rollback protection.
My Android security patch level is September 5, 2026, while the latest /e/OS build for the FP6 appears to be dated September 1, 2026. I haven’t tried installing it because I’m concerned about rollback protection. The available builds are listed here: /e/OS builds
It looks like builds usually arrive around the middle of the month, but I haven’t seen a newer one yet. I’m trying to understand:
- Does the build date or its included security patch level determine whether it’s safe to install, and how can I check that?
- Would an October build be expected to work, or could it still be blocked if its patch level is older than the one currently on my phone?
- Is there an official way to check whether an October FP6 build is planned?
- Should I avoid updating Android in the meantime, in case a later update raises the rollback level further?
- Is there a safe, supported way to install /e/OS now, or should I wait for a newer build?
- If I do need to wait, is there anything I should avoid doing so I don’t make installation harder?
I’d also appreciate pointers to the relevant Fairphone or /e/OS documentation. I’m not looking to bypass rollback protection, just trying to understand the supported options before making changes.
