since a few weeks I have serious trouble using phone services of Signal. Telegram and Threema. At first I thought it might be a hardware issue, however I found out that phone calls via whatsapp work well. I did some updates and it was a little bit better but still a problem which makes my phone unusable for such calls.
Does anyone have any idea what to do? This is a crucial function for me as I travel a lot and if I cannot fix that problem my Fairphone-Time would be over after 3,5 years
basically if I use the telephone or recording function of those messengers there is something like my voice in the very distance but basically loud cracking which makes it impossible to understand.
