I believe the headphone jack is slacking. When I touch the cord, sound stops in one hear. It’s the same with different headphones. Is this some hardware fix that can be corrected easily?
This happens to me regularly when enough dust has collected on the bottom of the headphone jack. It’s fairly easy to clean. I use sandwich bag ties to get it all out and afterwards the headphones connect firmly again.
Oh thanks! Do I just put the cleaner inside the jack, or how do you proceed
here?
I just sort of wiggle it around until I can dig out flakes of compressed dust. It’s hard to explain, but you can search for “clean headphone jack” on youtube and get tons of tutorials.
Can’t get it to work, any other suggestions?
I believe I must change the entire module, cause I been cleaning and
cleaning and the slack remains…
