If I make a picture with my FP2 the images are stored in /storage/emulated/0/DCIM/Camero/ as IMG_date_time.jpg.
But if I look at that folder with Amaze I see an empty /storeage/emulated folder
Also Ghost Commander shows nothing in /emulated
If you tap on the three lines in Amaze, you can instantly go to the SD card without starting from the root folder (which also doesn’t work for me). Then you should be able to go to the DCIM folder and access your pictures
