Not really asking for help and I have informed behind the scenes. This is to add detail and make it public.
A.0016.6
The story:
I tried to charge my phone using my usual way > A magnetic cable USB C to USB C with one end having a USB C to USB A adapter plugged into car charger and no apparent charge happening.
Testing with the phone off other than the yellow LED there was no battery icon showing.
- First I tried another phone. The same, no indication of charging by text and no flash symbol in the status bar. Switching off and on made no difference.
- Try a new cable in both phone ~ the same
- Tested the adapter with a USB micro to an old Samsung All OK
- So I wondered if the charger was failing to negotiate QC3 as the yellow LED did come on.
- I checked the battery via Settings > Battery No sign of charging > here is a screen shot
I was baffled as to why both phones would not charge and had the same screen info
- I thought ~ could it be the Gesture navigation that I decided to use on both phones and this is the first time charging either since that set up.
- Lo and behold by going back to 3 button navigation all is fine
Screenshot using 3 button navigation
