I was just wondering if there are still way to get a new FP1 case because mine is not holding on the phone anymore so it’s useless but I don’t know how and where to find a new one…
Thanks for the help !
Salut!
Je me demandais si quelqu’un saurait par hasard s’il y a encore moyen de trouver une coque de protection pour le FP1 car la mienne ne tient plus et ne sert donc plus à rien. Mais je ne sais pas comment et où cela pourrait encore être trouvable…
Are you talking about the metal part on the back underneath which is the battery?
If so first make sure the reason why it doesn’t fit anymore isn’t a swollen battery. In the #batteryguide you can find the spin test.
If it’s not the battery you might get the part in the #market.
Yes sorry, I was talking about the case you put on the all phone, not the metal one covering the battery ^^
But thanks about the tip anyway cause I have one battery that stays in place less good than the other and I didn’t know why and maybe that’s the reason.
I had heard about some 3D printed FP cases, do you know if it’s possible to have the document with witch we can print it ourself in 3D ? If it’s available…
