The Play Store App doesn’t find it, and the Play Store website says it is incompatible with my device and doesn’t let me install it.
This is correct, the hiccup app is an Fairphone app and isn’t supported on LOS… It also wouldn’t be helpful for the development of LOS anyway as the bug reports are sent to Fairphone and LOS is not supported by Fairphone.
to analyze the problem, you need the file last_kmsg. These must be provided by Chris.
Steven
Thank you Steven,
How do I find the file last_kmsg? And I don’t understand, why do I
need to find a file from Chris? Who is Chris? Sorry I am out of the
loop.
I suspect this is one of those nasty English problems… I think he means to provide TO Chris
You will find the file under the path /proc/last_kmsg.
Sorry for my english.
Hi everyone,
@chrmhoffmann
I’ve got some reboots as well with LOS.
Most of the times is a few minutes after an update.
It’s quite rare but it happens.
Otherwise it’s running smoothly.
You’ll find my last_kmsg.
https://drive.google.com/open?id=13cTE32QCZ9qqh0CLeMg8R6mYBs6kxK56
Hahh :), that’s fine, thanks Steven. I checked, and I only have
/proc/kmsg
but no /proc/last_kmsg
on my phone… Is there a way to
generate that file?
This file is generated by the system. Can not tell you anything exactly. Sorry.
My phone randomly restarted again, and this time I was able to find
/proc/last_dmsg, I’ve pasted the contents here:
https://framabin.org/p/?8e682dd2f9d19337#L35TsumxBR8wDhWD+XGU7brdrgvJsoNyaqCEuD5/MrU=
Is this information what you are looking for? What can I do to
diagnose the problem? Thanks!!
Hello again,
My phone had even more random reboots, and this time the
/proc/last_kmsg looks kind of different:
https://framabin.org/p/?9c42ac4700af993c#Xek41TitpkFIYW17sxaJJTrAqAR92NUXDtq/J8p8yKY=
Is this information helpful? Thanks for your help.
Hi, since some time (I guess som LOS release starting late may, early june, but maybe coincidence) I have to kill the mediascanner after reboot, otherwise the system will reboot. Normally, there also is a last_kmsg there. With consistent errors. Is this more a FP LOS issue, or is it something for LOS Gerrit?
[quote]
WARNING: at …/…/…/…/…/…/kernel/fairphone/msm8974/kernel/signal.c:2963 do_rt_tgsigqueueinfo+0x50/0x80()
Modules linked in:
[<c010f02c>] (unwind_backtrace+0x0/0x138) from [<c01b499c>] (warn_slowpath_null+0x3c/0x54)
[<c01b499c>] (warn_slowpath_null+0x3c/0x54) from [<c01c81a8>] (do_rt_tgsigqueueinfo+0x50/0x80)
[<c01c81a8>] (do_rt_tgsigqueueinfo+0x50/0x80) from [<c01c823c>] (sys_rt_tgsigqueueinfo+0x64/0x80)
[<c01c823c>] (sys_rt_tgsigqueueinfo+0x64/0x80) from [<c0108760>] (ret_fast_syscall+0x0/0x30)
---[ end trace d97097dc3f1ee6fd ]---
Unable to handle kernel NULL pointer dereference at virtual address 00000004
pgd = e9868000
[00000004] *pgd=00000000
Internal error: Oops: 5 [#1] PREEMPT SMP ARM
Modules linked in:
CPU: 1 Tainted: G W (3.4.0-perf-gd5178da #1)
PC is at sdcardfs_permission+0x8/0xd0
LR is at inode_permission+0x68/0xc0
pc : [<c036a354>] lr : [<c0295354>] psr: a0000013
sp : eb12df70 ip : 00000000 fp : 6f7c07e0
r10: 00000000 r9 : cedc34b8 r8 : 00000000
r7 : f497ec80 r6 : eb12df80 r5 : 00000010 r4 : cedc34b8
r3 : 00000000 r2 : 000f703d r1 : 00000010 r0 : cedc34b8
Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
Control: 10c5787d Table: 2986806a DAC: 00000015
and in the end
Process MediaScannerSer (pid: 8709, stack limit = 0xeb12c2f0)
Stack: (0xeb12df70 to 0xeb12e000)
df60: dc279200 00000000 eb12df80 c0289e00
df80: f38bf910 ead84c60 00000000 a7add7c0 00000000 a7abfc60 0000014e c01088e4
dfa0: eb12c000 c0108760 a7add7c0 00000000 ffffff9c a7abfc60 00000000 00000000
dfc0: a7add7c0 00000000 a7abfc60 0000014e acf462e0 a77f1a00 73bf9eb8 6f7c07e0
dfe0: 00000000 acf462b8 b6c2b7e9 b6564e74 800b0010 ffffff9c 00000000 00000000
[<c036a354>] (sdcardfs_permission+0x8/0xd0) from [<00000000>] ( (null))
Code: 009b00e8 000186a0 e5103004 e590c004 (e5932004)
---[ end trace d97097dc3f1ee6fe ]---
Kernel panic - not syncing: Fatal exception
CPU1: stopping
[<c010f02c>] (unwind_backtrace+0x0/0x138) from [<c010dcb0>] (handle_IPI+0x144/0x248)
[<c010dcb0>] (handle_IPI+0x144/0x248) from [<c0102ac0>] (gic_handle_irq+0xec/0x124)
unwind: Unknown symbol address c0102ac0
unwind: Index not found c0102ac0
CPU3: stopping
CPU2: stopping
wcnss crash shutdown 0
Rebooting in 5 seconds..
Going down for restart now
Calling SCM to disable SPMI PMIC arbiter
Also, in between there are a few SELinux denials
