since a few days (maybe two weeks or so) my FP5 (current updates) keeps restarting the UI three, four times a day. First, no app is running anymore. It opens and is immediately closed again. After a few minutes, the whole UI restarts (I is not the complete phone but really only the UI).
Any ideas what causes that issue or how to find out which app is doing that?
Thanks
Hello
Just brainstorming , you could check whether that happens also in safe mode.
Are you using the stock launcher?
Any recently installed apps?
Obviously you could do the factory reset and then start reinstalling apps one by one, but that might be a big task:)
Not quite sure about apps, but it was around the last update maybe. Isn’t there any way to find out what caused the restart?
