thats the result after trying to use the FP on the bike
But I can touch/use the device without problems – it’s “maybe” just a optical damage.
However: would it be possible to change the front glass? But how expensive will this be?
Go to enter link description here here you can see that a new display will costs you €71.39 based on Dutch tax. At the moment this display seems to be sold out.
There’s the possibility of a display from the B-stock, see display B-stock.
For more information what’s a B-stock display, I refer to the link.
@Webaschtl Many people do use their smartphones with cracked glass. I wouldn’t recommend it though, especially if there are any edges you can feel under you fingers and there does appear to be an actual chip in the glass as well as a fracture so it could easily get worse over time/use
Replacing the screen would be the best solution in the long term
Did you check the B-stock display link? That screen is only 48 euros, will enable to operate your phone near perfectly and you’ll help reduce unnecessary waste!
