FP6 Tap to wake
When I double tap on the screen to exit the standby mode, it doesn’t work very well, around 1 time by 4.
Any idea how to fix it ?
Same here. Do you have a screen cover? There’s an option at the bottom of the “Display” settings to increase Touchscreen sensitivity, maybe that helps - it did for me.
It just doesn’t work correctly. Not something that will be fixed anytime soon.
Do you have Settings > Display > Pocket mode enabled?
Thanks for your answers.
Yes, I have increased the screen sensitivity but that’s the same.
Grazie, Grazen. It’s a good suggestion which I’ll try. (Yes, I have a screen protector, and yes I have noticed the same.)
No here. What used to take 3-4 ‘double taps’ to wake the phone up now takes just the one (or max 2).
