Hi!
I’m having issues with the Switch on my FP6. It started a month ago when I got stuck in the Essentials without being able to escape it, I then found a post saying I could go into settings and change the Default App for Home app to Quickstep which I did and it fixed the problem temporarily. Although now I simply can’t use the Switch at all, when triggering it it just doesn’t do anything
When setting the Default app to FP Moments it just gets the phone stuck in the essentials again, even if the switch is off. I also tried moving the switch up and down when stuck in the essentials to no avail. I got stuck in Essentials a few times again, but thankfully I knew the fix!
I also tried to reset the app by going into Fairphone Moments and deleting the storage, setting the Default App back to Moments and when switching it to Moments it instantly locks the phone into essentials!
I’d also like to change the Switch’s action to Do Not Disturb mode but when entering the settings for the Switch specifically the settings app closes immediately. Sometimes showing Switch Button Settings is not responding, sometimes not (the settings app always closes though).
Is there a fix to it?
Thanks in advance ![]()
