FP6 spontaneous reboots
I bought a new FP6 a few months ago, on Android. i did all updates.
It has 2 major problems, which might have the same root cause
  1. it often gets unresponsive, or some functions (like bt music to car or agenda) get ‘stuck’. Even the contacts app, the ‘classic’ phone app and gmaps regularly get unresponsive (i did not do a systematic check but possibly every app can get irresponsive). Only solution which works: reboot. this happens several times a day
  2. it reboots spontaneously, on its own, which is a problem because I miss calls, for instance.
anyone experienced something similar?
on the fairphone aftersales service, one asks me to perform a long series of checks myself: I cannot spend all this time to help the debugging, it is completely irrealistic to perform all these tests myself.
… and if I’d check the boxes pretending I’ve done those tests, I’d have to send back my phone for FP to do the aftersales check: also impossible, I need it daily for work.
Any idea how to get around this? I’m stuck with a brand new FP6 which seems to have a major problem, with no way out…
cheers
Mine used to reboots hundreds of time per day. Then, fater one update, it went down to a few times per week. Then after another update it hasnt happened. It had something to do with cell towers. I dont know if it is the same issue as you
You are in the US and that was a very specific issue.
if you go on the Fairphone troubleshooting page, they ask you to perform a series of tests yourself, each taking up to a few hours to be done properly.
Assume you have several afternoons to lose to perform free debugging for FP because you still love them after having this issue repeatedly since you bought your brand new FP6 (or, more likely, you don’t love them anymore and just skip the diy debugging jobs)
then? they ask you to send back your phone to them so that they can check by themselves, and that it might take weeks. hmm that’s the point where your dedication to the brand is really put to test… because - for me at least - I cannot work without phone, so I have to use my vacation time.
but as I’m someone who is behaving ‘normally’, I’ll just wait a few more weeks with my cellphone rebooting randomly at least 10 times a day, loosing time and missing calls and meetings accasionally… and then buy a phone from a brand that cares about its customers by not releasing malfunctioning hardware, lose money by throwing away my brand new FP6 and spread the word not to buy FP anymore
it reboots anywhen, anywhere, at least 10 times a day… i’m not sure it could have something to do with cell towers.
if yes, then an update should have fixed it by now, no?
i did all updates.
i’m currently on FP6.QREL.16.111.0 in Switzerland
sure it’s not that kind of issues. reboots on its own even when it’s on a table with no one havig touched it for hours.
It’s hard to disagree with you.
I do, however, trust in Fairphone’s honesty toward its customers, even thougt, in terms of technical support efficiency, we are still a long way from the kind of standard that inspires customer confidence.
It would also be great to interact directly with the developers on this forum; however, aside from a certain rigidity necessitated by the need for order and discipline, it remains primarily a gathering place for users, with no guarantee that anyone directly involved in development or technical support is actually reading or considering the issues we encounter with their products.
If it’s any consolation, I remember when I bought my first smartphone (a Galaxy S4) back in 2013.
It initially had a bug that caused the phone to restart unexpectedly and spontaneously. Some time later, an update was released that permanently fixed the issue.
Let’s hope the same happens for Fairphone.
