I really miss the little light dot which I had on my former FP3, that turned red when the battery went under 20%. Is there an option for any kind of warning before battery empties and the phone turns down?
Thanks for hints, Nico
Since the FP4 Fairphones dont have a LED anymore
You can activate the Battery Saver (Settings → Battery & Charging → Batter Saver on A15) to turn on at a certain percentage, then you will see a notification
Not exactly a warning, but I configured my FP to enable the battery saving mode at 25% (default I think is a lot lower).
So when I see the battery saving is active, I know I have still enough time but should use the next opportunity to charge the phone.
But on a typical day I charge the phone around the same time and there’s usually still enough battery left. And I ensure that I don’t leave the house on less than 50% when it’s many hours before I return. It’s less of a deal as it probably sounds. Of course YMMV.
Thank you Ingo. It happens to me quite often that the phone lies around, and when I leave the house I only realise that the battery is almost empty. Maybe I’ll get better organized in the course of time, but I did appreciate the little support by the little red light. Best regards
